Really simple question, I've got 25mm mdpe pipe coming out of 110mm pipe/duct in the build.  Is there a widget/grommet that I can use to seal the 110mm pipe round the 25mm mdpe pipe, thought about expanding foam but not sure if the chemicals are safe to use with mdpe?
Thanks Marek
You will still need to insulate if this is less than 300mm from the perimeter of the foundations. Rockwool plus 25mm wall pipe lagging will suffice.
Exp foam is fine with MDPE btw ;) Just spray a little water into the 110mm pipe before applying to help it cure / expand.
Yep all insulated, pipe insulation from edge of build to rise, about 12m worth.  Did it as I was laying the ducting and pipe, probably one of the only jobs I did in the correct order...  I didn't fancy shoving insulation round the water pipe down through the bend.  I do worry that If I/someone ever needs to replace then pulling the pipe out + insulation then replacing might be a hell of a job though...
Found this factsheet if it's of any use to future readers.
Fact sheet - laying a new supply pipe.pdf
That pipe will last longer than us mate ;)
  • Haha 1
