hammerandnails Posted June 5, 2022 Share Posted June 5, 2022 Hi all, I'm replacing some door linings in a 1960s property which is mainly made up of clinker blocks, some of which are quite brittle. When I removed a door lining (held in place by cut nails) a big chunk of one of the blocks came away with it (lesson learnt!). I have some questions on how best to put this right: 1) What is the best way to repair this? 2) Should it be patched up before or after the new door linings go in? Doorlinings will be fit by a professional chippy. 3) Can it be filled with bonding when it gets re-plastered? Thanks! (pics attached) Link to comment Share on other sites More sharing options...
Roundtuit Posted June 5, 2022 Share Posted June 5, 2022 Not a big problem, and an easy enough fix. I'd get the new linings in first, assuming you can get a decent fix, then just fill in the holes with a stiff mortar mix and plaster over the top. Link to comment Share on other sites More sharing options...
hammerandnails Posted June 6, 2022 Author Share Posted June 6, 2022 12 hours ago, Roundtuit said: Not a big problem, and an easy enough fix. I'd get the new linings in first, assuming you can get a decent fix, then just fill in the holes with a stiff mortar mix and plaster over the top. Nice one, thanks. What ratio mortar mix is recommended? Link to comment Share on other sites More sharing options...
Conor Posted June 6, 2022 Share Posted June 6, 2022 27 minutes ago, hammerandnails said: Nice one, thanks. What ratio mortar mix is recommended? 3-4 to 1. Dampen the block and door lining a bit before or else it'll suck all the water out of the mix. You might need a couple layers. If you do, scratch lines in to the first coat before letting it go off and applying the second Link to comment Share on other sites More sharing options...
hammerandnails Posted June 6, 2022 Author Share Posted June 6, 2022 8 hours ago, Conor said: 3-4 to 1. Dampen the block and door lining a bit before or else it'll suck all the water out of the mix. You might need a couple layers. If you do, scratch lines in to the first coat before letting it go off and applying the second Cheers Conor Link to comment Share on other sites More sharing options...
