Black Cat Posted May 29, 2022 Posted May 29, 2022 Hi, I’ve read on here that the minimum room height for a loft conversion is 2200mm. Is this to the underside of ridge and would there be no need for a flat ceiling or should you have a minimum area of flat ceiling at 2200mm?
ProDave Posted May 29, 2022 Posted May 29, 2022 The actual thing that defines what will pass building regulations is the height above the stairs must be 2 metres and that includes the "landing" that is generally taken to mean 1 square metre of floor at the top of the stairs. If you can meet that, there is no actual minimum ceiling height for the rooms.
Black Cat Posted May 29, 2022 Author Posted May 29, 2022 Don’t think I will have a problem with the stairs and think I will be OK on the landing but was wondering if there had to be a minimum area of flat ceiling at a certain height in a habitable room or can the ceiling just go to a point. From what you are saying then no is the answer, I suppose it what's you would feel comfortable with and for me 2000mm is a bit low in a habitale room together with sloping ceilings. Idealy I would like 2300mm but may have to settle for less. Thanks ProDave.
