Taya McKinnon Posted April 26, 2022 Share Posted April 26, 2022 Hi, I'm hoping someone can help. We are having a two storey rear extension being done. Our bricklayer has done a vertical dpc on the second lift but not on the first?? Should the vertical dpc have been done on the first lift as well as the second? Link to comment Share on other sites More sharing options...
markc Posted April 26, 2022 Share Posted April 26, 2022 1st and second lift? Brick courses? Stories? And are you talking about a movement joint? Link to comment Share on other sites More sharing options...
Taya McKinnon Posted April 26, 2022 Author Share Posted April 26, 2022 Should there be a vertical dpc running between the inner and out skin all the way down the building to the dpc along the bottom of the building? Link to comment Share on other sites More sharing options...
ETC Posted April 26, 2022 Share Posted April 26, 2022 DPC and insulation required at the junction of the new and old wall constructions. Normally wall starter kits used or full cavity opened so that the cavities and insulation is continuous. 1 Link to comment Share on other sites More sharing options...
