Jenki Posted April 12, 2022 Share Posted April 12, 2022 I'm looking at getting my supply cables to get power from my Cabinet to a temp supply for a static and house / Pods. The cabinet is staying. So meter will be in there. I got to thinking about the meter. Can some one please confirm, that the meter will only need 1 supply (L&N) for both tariffs, and that the new dual tariff meters takes care of the different times. From the cut out / Isolator I will have a Switch Fuse, then planning on running a 6mm SWA to power the pods, and a 25mm SWA to the House. just want to make sure I don't need to run 2 L conductors (4 core cable) Link to comment Share on other sites More sharing options...
joth Posted April 13, 2022 Share Posted April 13, 2022 Generally the answer now is install a smart meter and this indeed only has a single L+N outlet. (assuming single phase!) A separate question is do you intend to turn on and off loads based on time of day/ economy times? If so you need separate timer (or more advanced control logic) for that but you can put that near the load it it's more convenient. Link to comment Share on other sites More sharing options...
