R values, thermafleece 90mm vs quinn therm 70mm?
Strawman
Hello folks
I have used an online calculator but thought I would check with a hive mind. I think the thermafleece is slightly better than the quinn therm. What do people think? Or has anyone got any other ideas? It is for a roof. The plan i to then cover it all with wood fibre too.
Thanks
For the love of cats I wish people would stop the love affair with PIR, especially in roofs.
Cost
Fire
Ease of fitting,
Thermal bypass,
Heat protection.
Vapour permeability.
Overstated K values,
Gas migration,
Shrinkage
poor performance in cold weather.
Supporting quantifiably immoral manufacturers.
On the other hand the sheep's wool will do fine. 👍
Cost
Fire
Ease of fitting,
Thermal bypass,
Heat protection.
Gas migration,
Shrinkage
Thanks for expressing that as I now don't have to 🙏 I tend to sound like enough of a grumpy git as it is 😁
Thank you Iceverge. Thermafleece is recycled plastic, still trying to calculate cost benefit. I had the nasty stuff leftover, it was as easy to fit as thermafleece and have yet to find anything cheaper. Its whether the R values are comparable. Maybe you know another cost effective product which has good insulation? I would be grateful to know. Thanks :)
