Tyler Posted March 6, 2022 Posted March 6, 2022 (edited) Hey all, wonder if someone can help me source a linkable under cabinet like this one ? I have been looking everywhere and I keep finding ones with different leads. Any help would be much appreciated Edited March 6, 2022 by Tyler
bassanclan Posted March 7, 2022 Posted March 7, 2022 https://www.eterna-lighting.co.uk/product/lft513wh/ Says discontinued
Nickfromwales Posted March 7, 2022 Posted March 7, 2022 @Tyler Check out TLC directs offering https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Kitchen_Index/Linkable_Flourescent_Fitting/index.html
dpmiller Posted March 7, 2022 Posted March 7, 2022 is the pin spacing not the same as an ordinary figure-8 plug?
Nickfromwales Posted March 7, 2022 Posted March 7, 2022 40 minutes ago, dpmiller said: is the pin spacing not the same as an ordinary figure-8 plug? The item in the OP looks to be a polarity-conscious connector, whereas the figure of 8 is not? TLC offering is difficult to say from pics. Shouldn't really matter tbh but the OP item may need the leads cutting to create a hybrid interlink.
Nickfromwales Posted March 7, 2022 Posted March 7, 2022 3 hours ago, dpmiller said: AC knows no polarity Agreed, and known. Yet OP pic shows that tooth which may be a manufacturer specific plug / connector vs the 'fits into anything, any way around' figure of 8 , and therefore it is likely the Interna plug / connectors will not go into the TLC fittings. Added for info so the OP can decide the best path.
Nickfromwales Posted March 7, 2022 Posted March 7, 2022 Yup. Male / female arrangement also, so no 'male' end on the light fitting itself can be touched when live and no connector inserted eg end of line fitting.
