New build in progress. Brick or stone outer. Block inner (carefully pointed, blocks themselves have independent test of very low air permeability). Plasterboard on adhesive frame & skim finish internally.
Cavity closers at windows/doors pose challenge. Uneven masonry finish. Builder used some silicon between closer and masonry. (pic)
Inclined to try putting a bead of Orcon F along that join.
Sensible? Worth doing to assist with airtightness?
How long to allow for a test bead of Orcon F to dry?
lZtTQyayCt13ErA8pxdYdMxkRqX3B9QP718SbRAVhRaT9T2dQiaRMhTU4ZMKve0OSrUhmbeBONK1KSFSWpgyilPxsY8ZBG3YXL1qbOwvmlNeF-88ccXlrhl27tHZcOHFLIdYNGP3BOyr_z8S530Li3iNqoWD0lxaCnWpYXWsz0aMauIaHbvkcPzOtS1oxbmwM3zom6SLvm5YFxjT_DJBkiPh-LTQKD4M0uiyYDxaF74AM8K8DPjv8sSg_tT2jSzOsFC3mA2ff8k46g_zRbLMcwSadfHB1WAi-BdkCl8b_v_-JorFySq8pU-UgxZBCVcTcIv6qb5ne4YfzY-X2QqR1FeDz84UfyXmSR6M_I7qUB5Qqu9V8qXfbRoIoa83oO8Uschi2EjZXjDPaOW-_L9srUT9pGs7Z_V9yHHwN_nOOYfNC5e-9plDK7GBxdJOjnXqmpDTrg3leCR6ocDynLSq5FifMLdKhwFBIhg-BL8DVeQ3V6eRwdI98cT07Tgdf9VoLQgtwqDh8PWC0yJ493rAXQ3cKk3A7oCd65FvQhiXfe15oRgZNAsJF6lFxDaO0poA9MmH9si-uVmtOYYL48NH50dpL1d4A2IAn90-QZB5Oqv9gREWq1gC8arJ-hT4VpLgAGvWdTn360r81HBo4YpxSShKuhHqY_Eqi6SRgt1vCk73koJpcnHY6acIqjY5FogN8gbBufp4JdVEEjFoZ6LEuv2laQ=w623-h830-no?authuser=0
You can get all sorts of airtightness tapes where you stick between the window or door frame and the substrate - in your case the blockwork.  I would not try to use the cavity closer as part of the airtight layer.
You will do this after the windows are fitted and before you dry line.
+ 1 to airtightness tape or similar. For masonry to other materials I've recently become a fan of the Soudatight LQ liquid membrane that also uses a goetextile tape to seal larger gaps.
