WWilts Posted February 24, 2022 Posted February 24, 2022 (edited) How to repair this load bearing block? Damaged when builder knocked through inner leaf foundation blocks at door. Cutting out and replacing would be structurally satisfactory. Is there any alternative? Edited February 24, 2022 by WWilts
Brickie Posted February 24, 2022 Posted February 24, 2022 If you want be a bit OCD you could use the tray as a shutter & feed some stiff concrete in there. Is it just that corner of the block that’s broken off? 1
WWilts Posted February 24, 2022 Author Posted February 24, 2022 50 minutes ago, Brickie said: Is it just that corner of the block that’s broken off? Corner on that block, and corners or bigger chunks on other load bearing blocks
WWilts Posted February 24, 2022 Author Posted February 24, 2022 39 minutes ago, tonyshouse said: No need to do anything That was acceptable to architect. Not to SE. Outcome: Patching the holes with 1:3 cement:sand mix (builder volunteered)
