Towel radiator pipes
Porthole
Hi there
Be grateful if you could please help. The builder has done first fix and put towel rad supply pipes in coming out of the wall. They are rigid pipes which are attached to flexible pipes further down. They are hardwalled into place but a bit wobbly. Does this matter? The rads will be fixed via their fixing points, but thought the pipes might be more secure than they are.
Thanks very much.
Hi @Porthole
Flexi pipes run under floors or in walls with copper through floor or wall to meet radiator is a common way to connect radiators. After fixing pipes to rad valves to radiator fill any excess space around pipe and wall floor and your done.
Good luck
Marvin
Edited by Marvin
Add info
