M2 costings
nod
With our start date looming closer
Something I’ve put off for a while Mainly due to constant material rises
Even muck away was up and thankfully down now
Most things seam to of either stabilized or are heading down  Even Pasquils quote of six months ago has dropped by 15% In any case I can base coatings on here and now
We finished our previous build three years ago So the spreadsheet for that was a good place to start and a way of not missing what seemed  like small items Off the new spreadsheet
Previous build came in at £815m2
Two story Traditional build
Two detached garages
Very good quality of finishing
Ive noticed this morning  That I never included the m2 of the two detached garages Just added the cost into the overall build cost
So the 815 was probably lower
But I will still split m2 of the house and garage - Workshop
As overall is 416m
The actual house is 308.21
I feel quite confident that our budget of
350k should be ok
The ground is a lot better now
We had a tank and three 4 meter holes to fill Two with concrete and thankfully the the third with hardcore
I Once I get the foundations in
I should be able to cost most things accurately
We finished our previous build three years ago So the spreadsheet for that was a good place to start and a way of not missing what seamed like small items Off the new spreadsheet
As overall is 416m
350k should be ok
I’m 60 now Last time we did most things while working full time
so hoping not to do to much of the block work this time
Perhaps just the foundations
But pretty much most other things
We've just moved in our 450sqm dormer bungalow which has cost us £325k with the VAT to be reclaimed on the materials ( we think around £30-£40k to come back). We did get the bulk materials before the price increases and I did loads of the work myself, foundations, laboured on brickys, fitted all insulation, wired and plumbed and plasterboarded most of it, fitted mvhr, decorated, fitted the kitchens and bathrooms etc etc etc. I went part time at work to do this.
Its still possible to build under £1k per sqm but you've gotta out the graft in!
Definitely
We both worked four days and worked the other three on the house I worked each evening While I don’t intend doing as many hours this time
I’m confident that our 360 will build the house and workshop combined 316m2
The key is the laboure
I have run a plastering- framing and  tiling business for many years But didn’t use any of the lads
Sort of felt like cheating Plus most earn several hundred per day and I was conscious of the cost
Your home looks fantastic
Well done
Edited by nod
