Marko Posted January 31, 2022 Posted January 31, 2022 (edited) I'm on designing of one of these fancy garden buildings, but it's to house my future racing pigeon team! However, it will be a full on build, insulated, electrics, MEV system the full works to keep them in good condition and hopefully win some races. It will fall within permitted dev. so under 2.5m. Apart from the fact that the timber will be unregularised, what are some of the other cons of using ungraded timber? Will it affect structural integrity, interfere with the insulation. I'm trying to think of any major impediments. Just trying to strip some of the cost out of the build. Working drawing is attached if anyone's interested in the layout. Framing Assembly1.pdf Edited January 31, 2022 by Marko
Simplysimon Posted January 31, 2022 Posted January 31, 2022 why not use regularised timber? is it that you have timber lying around to use? if you are using what you have to hand then insulating and sheeting will be difficult. used to build houses from off saw timber and there's a very good reason nobody does it any more. buy some c16 cls and make life easy for yourself.
Marko Posted January 31, 2022 Author Posted January 31, 2022 3 minutes ago, Simplysimon said: why not use regularised timber? is it that you have timber lying around to use? if you are using what you have to hand then insulating and sheeting will be difficult. used to build houses from off saw timber and there's a very good reason nobody does it any more. buy some c16 cls and make life easy for yourself. No reason other than cost of ungraded vs. graded. But, I thought I’d ask people in the know beforehand. If it’s going to make life difficult, like you say, then I’ll stick with the graded stuff. Thanks.
Marko Posted January 31, 2022 Author Posted January 31, 2022 Just now, Simplysimon said: how thick a wall were you thinking? 100mm I’m planning on.
Marko Posted January 31, 2022 Author Posted January 31, 2022 9 minutes ago, Simplysimon said: go with 89mm cls as opposed to 95mm reg Cheers Simon, I’ll have a look at that.
Faz Posted January 31, 2022 Posted January 31, 2022 My last load of 4x2 cls was £9.50 plus vat per length. Cheaper to plant an acorn and wait..... What a joke.
Simplysimon Posted January 31, 2022 Posted January 31, 2022 36 minutes ago, Faz said: My last load of 4x2 cls was £9.50 plus vat per length. Cheaper to plant an acorn and wait..... oak cls, there's an idea.....
