Breville mini is fab
SWMBO got a seperate bean grinder ( only takes seconds ) and the latte she makes is better than most coffee shops .
Our Magnifica must be getting on for 10 years old now. Lots of spares still available. Fitted a new O ring kit while ago and got a replacement steam control valve assembly. Still runs fine although the coffee strength dial (grind timeout)  has a worn spot on the potentiometer track and if used at a particular position on the dial can grind for so long that the hopper overtops! If anyone finds lots of dry coffee grounds in the base of the unit, take a look at the spent pucks and see how thick they are. Someday I'll change the pot but in the meantime I've just sharpied the no-go zone above the pointer.
