Is it possible to work out the output of a radiator at a certain delta? I’m not sure our plumber has sized our new rads correctly despite insisting that they’re ok.
They’re column rads, and we’re looking for a delta of 50 not 65 which is what I think he is using.
Thanks!
9 hours ago, JohnMo said:
Have a look on the manufacturer website, they now list various delta T, if not give them a call or the UK agent.
I don’t know the manufacturer, the plumber dropped them off 2 days ago.
this is all I have…
Thanks @Roundtuit and @JohnMo
thus is for a room that needs around 4900BTU. The plumber has specified 2 of them knowing we’ll be running out heating at 50deg and knowing we want to upgrade to a heat pump in the future.
radiator outlet says 2700BTU per rad but with no delta, home supply suggests 2200BTU at a delta of 50.
should I get the plumber to change them for something bigger?
