EPS beads vs blown glass mineral vs cavity batts
We are looking at a brick and block construction with a 150mm cavity.
What experience has everyone got with the above option and can anyone recommend a particular insulation method for a 150mm cavity?
At the moment am favouring a blown in product as it’s guaranteed 100% coverage but would be interested to hear peoples thoughts on price and performance?
EPS bead all the way as long as the brickies keep the cavity clean - easily done but they need to be watched so you dont get lots of mortar in the bottom of the cavities. Beads flow very well so you get a decent coverage.
Batts need care when being installed and can end up with gaps.
Would you recommend a particular EPS bead product?
250mm EPS beads here. I would consider batts if I could put them in myself or use a trusted builder.  There's a pretty comprehensive thread here.
Any of the graphite EPS beads tbh are fine as they are all made by one or two manufacturers.
