Question on how we join the DPC to DPM.  And is it important if DPM goes over or under the DPC?
Build up is Block and beam floor, block work inner walls with DPC sticking out about 12 inches in places.  My floor insulation has arrived and is in a nice big pile, so In order to reduce said pile I was thinking I could get the floor swept, DPM down and start laying out the insulation, or more likely I could task Mrs Wafer with the job whilst I play with stud walls.  I've got a couple of rolls of heavy DPM, loads of double sided butyl tape and plenty of tape for the joins ready to go, but as usual when it comes to the finer points questions start getting asked.  So over or under, is the question?
DPM over DPC:
- DPC is pretty rigid, by the time you finish the roll of double sided tape, it may lift off where you started
- you want  to fold DPM nicely in internal corners / fix in external, so it needs to be on top
Thankyou.
That toolstation tape is the stuff I had, it wouldnt even stick to my fingers, maybe I had a bad batch, or it was too cold or combination...  I'll experiment with a heat gun on it and see if it improves matters.
Semantic question, should it go on top or underneath the insulation, I always put it on top arguing that there it would act as a vapour barrier too, whereas underneath it could actually collect condensation if it got below dew point down there.
Well, applying heat works a treat, a quick blow over with my gas torch and it's stickier than a sticky thing and the dpm has bonded nicely.  This heavy dpm is under the insulation, but was planning something over the top of the insulation too,  i was told something about screed eating the insulation and stopping the insulation from floating when the screed is poured.
All the manufacturer's detail's I've seen asked for both. Even though in beam and block it is debatable how much damp can cross the air gap underneath
Yes, the top layer over insulation, including perimeter (if rigid used, not the thin lagging) - those stripes are light and set free immediately, don't ask how I know
Manufacturers don’t pay double for anything, they are out to protect themselves and get away with the unnecessary, I hate waste and doubling up
how long before they ask for a double dpm?
