Ferdinand Posted April 18, 2017 Posted April 18, 2017 Following on from January's Cost of triple glazing thread, is anyone willing to share the approx cost of their double glazing? I will be receiving my quote for the Little Brown Bungalow replacement DG this week, and would welcome some comparisons. In theory I should be in a good place, because my DG man measures up and has it made half a mile down the road, and I can't see how that can be improved. Cheers Ferdinand
PeterW Posted April 18, 2017 Posted April 18, 2017 Drop a couple of sizes / glass specs on here and I'll see what mine comes out at ...
Ferdinand Posted April 18, 2017 Author Posted April 18, 2017 (edited) On 18/04/2017 at 09:28, PeterW said: Drop a couple of sizes / glass specs on here and I'll see what mine comes out at ... Will need to measure up. Will reply later today. Ok @PeterW here you go. I need the following supplied and fitted.:Full details but an approx indication is fine. White uPVC. Everything is grade A with chromes handles and high security (anti bump, anti snap) locks. 225mm or ideally 250mm sills. Spec of unit is 4-20-4 float glass warm edge argon filled. I make the u value 1.4-1.5, so Ok for DG but not as good as is available. Front door: 2.1m h x 1.5m w door (900) and flush upvc side panel (600) Door 2 light top half with mullion, raised panel below. Back door: 2.1m h x 0.9m w door. Door identical to front door. Picture window: 3m w x 1.3m h. 1:3:1 division into lights. One light opening. Window: 1.2m h x 1.2m w. 1:1 division vertically. One light opening. Window: 1.0m h x 1.2m w. 1:1 horizontal division. Bottom light opening. Window: 0.9m m h x 1.2m w. 1:1 horizontal division. Top light opening. Window: 1.2m h x 2.2m w. 3 lights. 1 light opening. French doors.2.1m h x 1.8m w. Both doors opening. There will be a certain amount of building work (eg French doors replacing window but no lintel needed), which I am excluding. Ferdinand Edited May 13, 2017 by Ferdinand Dimensions included.
Ferdinand Posted April 24, 2017 Author Posted April 24, 2017 On 18/04/2017 at 10:25, Ferdinand said: the following supplied and fitted Quote for the above is now in. It comes to about £3200 including fitting, which I make £170 per sqm for 19 sqm. A run through on Double Glazing on the Web gives a range of £4200 to £6500. Ferdinand
PeterW Posted April 24, 2017 Posted April 24, 2017 Thats a good price - what's the uValue on the units..? Local company too..?
Ferdinand Posted April 24, 2017 Author Posted April 24, 2017 12 minutes ago, PeterW said: Thats a good price - what's the uValue on the units..? Local company too..? Will pm you.
