On 04/12/2021 at 10:22, nod said:
run a plastering business and drylined the external walls will 37 mil insulated plasterboards Far superior to wet plaster
Hi @nodI have noticed a big price difference between PIR insulated plasterboard and an equivalent insulated with a polystyrene like material.
  1. Did you consider both options?
  2. Did you choose the more expensive PIR insulated board?
Yes there is a difference
We don’t have much choice in what we use
Nearly always the Architects favorite
Kingspan and pink foam backed PP for dabbing
2 hours ago, WWilts said:
Is that "scrim"? Our builder says his plasterer will use scrim and then skim over that
A lot of the older guys still call fibre tape Scrim
Worth using paper tape around the angles
Less cracks
