My Little Brown Bangalow has a narrow side-path at 960mm wide.
And there is a damn great gas meter box 220mm deep ie front to back, which makes moving things problematic and even dustbins are a little tight.
Q 1 - Simple question - can I get a shallower box for my gas meter?
The only option I can currently see is a recessed one, which could be an answer.
Q 2 - Can my gas man do such a change or would it be the gas company and forking out a large number of notes?
Cheers
Ferdinand
Edited by Ferdinand
Meter moves are a Transco only job - £6-700 from memory but check their website as it has a decent price estimator on it.
Does the pipe come up the wall externally as an option is to use a partially buried box but they need a different type of meter so again I think you get charged by someone for it....
Uh-ohhh ! Wrong answer >:(.
Previously the meter was inside the kitchen and was moved externally, so without going to look I assume it comes straight in to the back. What I need is a recessed meter buried in the EWI, but I am better living with the depth as at least it has some insulation in the wall.
My EWI man has said I have to leave 75mm right back to the wall all around the thing, but it is not worth £600 to fix it.
I might look at putting a slab against the wall inside.
Are any risks attached if I put say a collar of 100mm XPS or Celotex around the meter box against the wall?
Ferdinand
Edited by Ferdinand
