Hi all
We have underfloor heating fitted between joists on our FF and Loft.  We have laid 18mm Caber boards over this, and before putting on the engineered wood flooring we were looking for the best underlay to use in this situation to help with heat transfer.
This is an interesting problem as usually we are looking to thermally isolate elements, not join them together.
Underlay also needs to deaden sound and allow some 'bounce' underfoot.
So I thought I would look at two common materials, rubber and cellular rubber.
These have thermal conductivities of 0.13 and 0.045 W.m-1.K-1 respectively.
Now assuming that the underlay is only 6 mm thick, then:
Rubber 0.006 [m] / 0.13 [ W.m-1.K-1]  = 0.0462 [R = m2.K.W-1]
1 / 0.0462 [R] = 21.65 [U = W.m-2.K-1]
Cellular rubber 0.006 [m] / 0.045 [ W.m-1.K-1]  = 0.133 [R = m2.K.W-1]
1 / 0.133 [R] = 7.52 [U = W.m-2.K-1]
So cellular rubber will be 3 times more insulating.
Edited by SteamyTea
0.13/0.045 = 2.88 - yep, one is 3 times more insulating :)
Not sure how flat the floor finish is, my understanding has always been that the purpose of the underlay is supposed to mask all the imperfections of the subfloor first and then add impact sound insulation.
The product I'm looking at is https://www.interfloor.com/app/uploads/2016/08/Heatflow-Wood-Laminate-DURALAY-TS-3.pdf . Although R = 0.035 m² K/W, at 3mm thickness only it gives overall U=28.6 W/m²K. 3mm thickness requires decent floor finish though.
Expand
I appreciate the detail.  Our floors are reasonably flat as we had new joists out in and the caber above.
The products I was looking at are
https://www.carpet-underlay-shop.co.uk/products/thermo-pro-x-underfloor-heating-underlay-for-wood-or-laminate
https://www.everbuild.co.uk/products/adhesives/floor-adhesives/sika-silent-layer-mat/   this comes in 3mm and 5mm.
  On 29/11/2021 at 20:23, revelation said:
Expand
They do not show the thermal conductivity, but it could be estimated from the data sheet.
It has a density of 30-33 kg.m3 and is made from polyurethane.
Expand
This one has a Tog rating of 0.3
A Tog (comes from the word for clothing, Toga)1 TOG = 0.1 m2.K.W-2.
So at 0.0018m thick
0.0018 [m] / 0.9 [ W.m-1.K-1]  = 0.002 [R = m2.K.W-1]
1 / 0.002 [R] = 500 [U = W.m-2.K-1]
It should really be called a thermal conductor, not an insulator, but it is very thin.
Edited by SteamyTea
Nah, why overcomplicate again?
Stated 0.3 tog => R = 0.03 m2K/W
U=1/0.03=33 W/m²K
Clearly the winner, the trick used of course is thickness of next to nothing - but if the floor surface permits, that is the way to go.
