I’m about to start wiring in the control centre for the UFH. It’s a Hetta system that seems great so far except the wiring diagram sent with it doesn’t quite match the box. I can’t find an earth point for the incoming mains and I’m fairly sure it needs earthing. Along with the manifold pump which seems to only have connections to a live/neutral with again no earth.
Is this the earth for either or both?
tia!
I would think so but I would want to be sure.  I suspect that pair of terminals just join to each other and nowhere else.  Personally I would unscrew the boards and have a look at the pcb tracks to confirm that.
I have a question.  How do the room thermostats connect to that controller?  I see no terminals?  Is it all wireless?
thanks @ProDave, good shout - I’ll have a look. Yes all wireless here! Retrofit so not chasing in cables everywhere!!
Yep, that looks fine.  There is no need for an earth connection to the unit, it is just a means to join all the earth wires together so the pump etc get an earth connection.
