luz624 Posted November 26, 2021 Posted November 26, 2021 A number of the plasters we plan to use (lime and clay) require temperatures over 5degrees. Our home currently doesn't have heating. We will have boarded up windows/doors until February. Is there any way we can still plaster internally, with the use of gentle heaters (and possibly a dehumidifier). If so, is there any advice for what type of heaters? And a solution for overnight - we are not living at the site, so I'm not sure what heating solutions can be left on while unattended.
nod Posted November 26, 2021 Posted November 26, 2021 1 hour ago, luz624 said: A number of the plasters we plan to use (lime and clay) require temperatures over 5degrees. Our home currently doesn't have heating. We will have boarded up windows/doors until February. Is there any way we can still plaster internally, with the use of gentle heaters (and possibly a dehumidifier). If so, is there any advice for what type of heaters? And a solution for overnight - we are not living at the site, so I'm not sure what heating solutions can be left on while unattended. I’m currently using Clay works on one of our jobs At £80 a bag you need to be careful with the wastage 5d is a guide As long as it doesn’t drop below 0 during the night Definitely don’t use heat Clay needs to dry slowly Or will crack before you get a chance to splay the hardener on 1
luz624 Posted November 26, 2021 Author Posted November 26, 2021 @nod nice - we are actually planning for Clayworks finish too. But even before we get to that point, we need to do the prep plastering with lime/clay (some base coat plastering, and then plastering over the carrier boards (some wood fibre, and some clayboards) Do you think no heat at all? Even indirect heat, just to get the space a bit warmer. I can see a few overnight temperatures of -1 coming up, which worries me!
nod Posted November 26, 2021 Posted November 26, 2021 The Clay works can be applied to plasterboard or fibre board Just needs CW primer first Definitely no heat The lime p and Clay W needs to dry naturally When we us it in summer we leave fans running to stop it drying to quickly Weve just done the boardroom at a football club Which is back in use tomorrow They are not happy that they can’t put the ASHP on till Wednesday When we go back to seal and harden it Be sure to see the installers work prior to them starting the job There are three grades of Clay Works Ive been using Clay Works Lime and Venetian for 35 plus years and still find it difficult to get experienced applicators 1
SteamyTea Posted November 27, 2021 Posted November 27, 2021 16 hours ago, nod said: Definitely no heat The lime p and Clay W needs to dry naturally When we us it in summer we leave fans running to stop it drying to quickly Why do you put fan on, us it to reduce the internal relative humidity?
nod Posted November 27, 2021 Posted November 27, 2021 5 minutes ago, SteamyTea said: Why do you put fan on, us it to reduce the internal relative humidity? Yes just to keep the air moving
luz624 Posted November 29, 2021 Author Posted November 29, 2021 @nod thanks, we are using clay/lime below for the benefits of those materials (i know it would be easier to use regular plasterboard, so we're not making it easy for ourselves!). Do you know if lime is the same, i.e. no heat?
Gus Potter Posted November 29, 2021 Posted November 29, 2021 On 27/11/2021 at 15:16, nod said: Yes just to keep the air moving Nod.. great posts. Am I right in saying this? Lime plasters need to be dried out slowly. Like concrete they need moist air and a moderate temparature to allow the chemical reaction to take place. The carbon dioxide in the air facilitates the chemical reaction as it's a non hydraulic lime base.. the moisture in the air prevents it just drying out while the reaction takes place over many days just to take up. Shrinkage is thus hopefully controlled. The fans are there to circulate the air not to reduce humidity and they serve to keep an even temperature / humidity over the wall from top to bottom. If you plaster a wall with gypsum plaster (which does not require carbon dioxide to harden) it dries out first at the top as heat rises, the fans are used on the lime plaster to encourage the wall to cure eavenly from top to bottom? You can't have you cake and eat it! Lime plasters need love and care and TIME.. you can't rush nature and some chemistry.
nod Posted November 30, 2021 Posted November 30, 2021 Exactly I’m going to spray the hardener on Clay works on Weds At a multi million pound extension on a football club They have had to delay firing up the bio boiler for nearly three weeks There not happy Your spot on You can’t have your cake and eat it The lime plasters shrink and crack if they are not left to cure Sealing or polishing to early effects the appearance Im lucky that most of this work comes via two very savy designers
nod Posted November 30, 2021 Posted November 30, 2021 7 hours ago, luz624 said: @nod thanks, we are using clay/lime below for the benefits of those materials (i know it would be easier to use regular plasterboard, so we're not making it easy for ourselves!). Do you know if lime is the same, i.e. no heat? Definitely no heat
