SIPS U values
Just sent out my architect drawings to 4 well known SIPS manufacturers for quotes. Its a 340m2 house, barn type structure. I have 2 quotes back, similar pricing but quoting very different panels. One has quoted 150mm thick panels for the walls and roof but they are polyurethane sandwich with a U of 0.024 w/m2 which seems incredibly low. The other is 194mm for the walls and 219mm for the roof but polystyrene sandwich with U of 0.18 w/m2 and 0.15 w/m2 respectively. The U value for the polyurethane SIP seems incredibly low and it is the thinner panel. Anybody got any experience of polyurethane vs polystyrene panels?
Hello and welcome,
That number is most likely the thermal conductivity of the polyurethane not the U-value of the whole panel. The U-value of a 150mm panel is likely to be a little below 0.16W/m2.K
Thanks and glad to be here. From what I gather PUR has a better thermal performance than EPS resulting in a thinner, lighter panel. I can imagine that PUR panels are more difficult to manufacture compared to EPS. As long as the thermal values are comparable, thicker panels are not a bad thing, just need to take into account transportation and handling.
11 hours ago, Goggs said:
Sounds good. It is SIPS ECO that have quoted the thicker EPS panels. What was your experience with SIPSECO from a service delivery perspective?
I can drop you a pm with some details.
Panels quality good, everything else needs more details.
