41 minutes ago, TheMitchells said:
If we are tanking then using the Multipanels over, it seems a little over the top to use Aquapanels too.  Would I be okay with green moisture resistant pb like the rest of the room.  I can then tank the whole shower area before applying the multipanels.  Aquapanels are quite a lot more expensive.  would rather spend the money on decent multipanels, as per Jeremy's.
If you are using multi-panel, why are you even bothering using anything on the block work ..? It can go straight to the blocks.
I promised the builder I would tank the area!.  it looks easier to tank pb than the blockwork.??  and we used the multipanels before, usung Jeremy's technique at the base so I will do that again.  Thanks Guys!  I dont mind a couple of extra pb's but I certainly am glad I dont have to buy Aquaboards.  As usual, BuildHub saves me money!
