Going to fire up the UFH I've installed recently tomorrow, fingers crossed.
Is it necessary to install and pair the thermostats? (They're wireless smart stats), or can I simply open the actuators fully and then slowly increase the heat via the mixing valve?
If the system is fully wired then with no thermostats there will be no call for heat on any zone = no UFH pump running and no call for heat to the heat source.
So at least 1 thermostat will have to be working or linked out to get something to happen.
