My new driveway has to be SuDS compliant and I have been given some nice grey pavers which would do the job, but I don't think they are permeable. They are to go on a Type 3 Mot sub base, and onto sand and my understanding is that if there are gaps for the water, it would be SuDs compliant. Is this correct and any suggestions as how best to do it please?
Thank you
If the joints are sanded rather than pointed
Water will soak right through
BC will be fine with that
There are special pavers that are shaped to leave a 3mm gap between.  The system requires special fines free sub base and pointing with a kind of grit.  All very expensive.  If your BC accepts normal kiln dried jointing sand then that will be good, although not permeable / SUDS compliant.
https://www.marshalls.co.uk/commercial/permeable-paving-and-suds
Edited by Mr Punter
Link to Marshalls added
We used 400m2 of Toblemore
Rock solid mot with 50 of grit sand on top
BC where  fine No probs with drainage
Edited by nod
