Do I need an architect?
Hi guys,
I am doing some planning / prep into self build and now I have a rough idea of what I'd like to build, I started researching architects.
But then reading on here, I started to wonder if I actually need one or whether I can save money by just using something like a house designer? I'm not looking to build anything super crazy.
I'm planning to build at Graven Hill in Bicester and have worked out that I could fit my build onto the smallest plots they do (main house would be max 80 m2 plus basement max 32m2).
I haven't actually reserved a plot yet but have started planning on roughly that basis.
In terms of build decisions (need to do more research but initial thoughts):
I've read that ICF build system is good for basements so I think I would use that for the main structure and SIPs for the roof, but I haven't ruled out going full PassivHaus dependant on budget, which I think means SIP's for the whole thing?)
Vinyl siding classing
Concrete roof tiles
Aluminium windows, doors, pocket sliding interior doors
Timber stairs
Underfloor heating
Unsure of flooring - maybe quarry tile
Heat pump
Solar panels
Unsure on smart features - worth it?
In terms of room layout (dimensions subject to change depending on exact plot):
Top floor - Bedroom and ensuite (4m x 4m), Studio (4m x 3.125m)
Ground floor - Lounge (4m x 3.5m), Kitchen (4m x 4m), Porch (1m x 1m), Utility room / Conservatory (2m x 4m)
Basement - (Gym 4m x 3.5), Hot tub/ sauna/ shower/ toilet (3m x 4m)
Other - Lift servicing all floors as well as stairs
I have a rough idea of layout too
Is it worth planning in such detail or does some stuff have to be left until later?
Is £1500-£2000 per m2 still a reasonable ballpark build cost figure? I would have limited involvement - just hire a main contractor / project manager
Does anyone have any recommendations for builders in and around Oxfordshire? I guess architects / home designer it doesn't matter about location.
If anyone has any other suggestions or if it would be helpful to get more info from me, please let me know.
I'm just getting started on my self build journey and there's so much I don't know / probably haven't thought of ?.
Cheers,
Chris.
We didn't use an architect for the design stage, however we do have an architect now to conduct stage sign offs who did give the plans a once over when he came of board.
Imo, that is too little based on your plans and involvement.
I have completed a lot of the works myself and project managed. We'll come in around £1450-1500 per sqm. We also live in a much cheaper part of the country (Argyll) in terms of labour costs compared to Oxfordshire when trades have been needed. I'm sure others will pitch in with views, but I'd say £2500 per sqm would be a better estimate, especially considering builder shortage at the moment. Now I have been through most of the process myself, £1500 with a builder is a thing of the past.
Quick answer is No you don’t need an architect
But for around a £700-1000  I would bring in a STructual engineer
We came in at £815 m2 two years ago on very difficult ground
and hoped to come in around a £1000m2 for our next
But with most things doubling That figure is likely to be more like £1500m2
For  340m2 build with large garage and workshop As with our first build Shopping around will be key
Also a much better ground than last time
I think also the size of your build has a big impact on on the cost per m2
Your survey fees Conections fees etc Will be the same for a large house as a modest house
@djcdan Thanks for your reply.
Did you do the initial design yourself or did you bring someone other than an architect in?
Thanks for your thoughts on build costs, that's good to know at this stage. Hopefully when I come to build, there won't be such a builder shortage (couple of years).
@nod Thanks for your reply.
But for around a £700-1000  I would bring in a Structural engineer
Thanks, I will look into structural engineers
Your survey fees Connections fees etc Will be the same for a large house as a modest house
OK cool, so looks like I need to up my build cost estimate for my modest house
