zzPaulzz Posted January 7, 2025 Posted January 7, 2025 Thanks all. I’m convinced by the ‘elevation argument’. Just not sure that the separation of 410mm is enough. I’m promised some evidence from the designer so will report back.
Bancroft Posted February 27, 2025 Posted February 27, 2025 To widen the topic... Has anyone had any experience of putting MVHR inlets/exhausts into a seamed metal roof? With our build, the most logical place to put the MVHR unit will be near a gable end closest to the approach to the property - so inlet/exhaust holes will be quite visible. Also, they will be facing into wind rather than downwind. One option I'm considering is to have the inlet and exhaust in low profile cowls on the seamed metal roof so that they can be in the lee of the wind and on the side of the house only horses will see. Apart from the obvious issue regarding waterproofing and insulation, are there any technical issues that might preclude this as an option?
JohnMo Posted February 27, 2025 Posted February 27, 2025 4 minutes ago, Bancroft said: MVHR inlets/exhausts into a seamed metal roof? I wouldn't. 5 minutes ago, Bancroft said: most logical place to put the MVHR unit will be near a gable end closest to the approach to the property - so inlet/exhaust holes will be quite visible Most logical is generally the best place. Competition Spot the MVHR vents, this is the road side. Inlet and outlet?
zzPaulzz Posted February 27, 2025 Posted February 27, 2025 Right in the middle? Upward and downward combined vent? Neat.
Adsibob Posted February 28, 2025 Posted February 28, 2025 8 hours ago, JohnMo said: That is rather a spectacular looking house. Well done for building that! 1 1
