External plastering - beam
Moggaman
4 hours ago, Moggaman said:
Hi. How does a plasterer sand cement render the beam section here please?
thanks
You would normally shot fire a sheet a 2400 x 600 mesh under the steel The lift and rap the face of the steel Then plug and screw to the block about 300 above
Or as above cement board but you would need to add a movement joint where the board joins the block
