epsilonGreedy Posted October 11, 2021 Posted October 11, 2021 I need to comp into a small section of masonry wall for a local repair, actually a few locations. Nothing more than 1ft across. My options seem to be blades that look like a wide multitool plunge blade and the other option is a semi circular blade. Which multi tool blade should I choose? In ascending order of harness I need to cut into and remove bits of the following: Fibolite (clay bubbles) internal wall block. Mortar. Regular clay bricks. Denser coursing concrete bricks. Looking at these: https://www.toolstation.com/smart-multi-cutter-mortar-buster-blade/p46597 https://www.amazon.co.uk/Bosch-Starlock-Carbide-Riff-Remover-Multi-Tools/dp/B009TGOMJ6
Nick Laslett Posted October 11, 2021 Posted October 11, 2021 I find the Bosch Professional website a good way to narrow down which blade type can do what. https://www.bosch-professional.com/gb/en/multitool-accessories-2865193-ocs-ac/ Use the filter button to select the material type. This works for all the different tool blades, grinder, circular saw, drill, etc.
Mr Punter Posted October 11, 2021 Posted October 11, 2021 A grinder will be better. You won't cut brick and concrete with a multitool.
