I know you can use either wafer head screws or a stud crimper to joint metal frame together, but wondered what people actually tend to use. I like the idea of the crimper not leaving heads that stick out and the plasterboard has to go over. What do the pros use?
@Conor looks like your MF contractor used some wafer screws, but did they use them through out or also use a crimper?
I’ve crimpers but like most only use them if I can’t get a wafer point in
Once crimped they are hard to un pick
All the internal studs are never fastened
Just one at either edge
