Jimcub Posted September 25, 2021 Share Posted September 25, 2021 I installed this in late 2016 and has worked flawlessly since then, it is in a conservatory with 3 zones the pump is a grunfos upm3 hybrid with a purpose build manifold and a bypass valve. turned off in May this year and then put on in august to test and worked ok now I had a faulty valve in the boiler which was fixed under guarantee, this fault drained all the water out through a vent so I had to refill every day 3 times, always empty in the morning. Now when the underfloor heating comes on the return heats up before the flow on the manifold, the pump is working. I flushed the pipes to get rid off any air pockets and it now has 2 bar pressure, but the actual pipes flow and return remain cold any help would be welcome Link to comment Share on other sites More sharing options...
TonyT Posted September 25, 2021 Share Posted September 25, 2021 Still air blocked , flush 1 zone at a time Link to comment Share on other sites More sharing options...
Jimcub Posted September 25, 2021 Author Share Posted September 25, 2021 (edited) Thanks I’ll give it a go in the morning, battery change on car today ( taking all the inlet apart just to get at it ) Edited September 25, 2021 by Jimcub Link to comment Share on other sites More sharing options...
SteamyTea Posted September 25, 2021 Share Posted September 25, 2021 43 minutes ago, Jimcub said: Thanks I’ll give it a go in the morning, battery change on car today ( taking all the inlet apart just to get at it ) Then spend the rest of the day looking for the radio security code. 1 Link to comment Share on other sites More sharing options...
Jimcub Posted September 26, 2021 Author Share Posted September 26, 2021 Ha no as it’s kept in the ecu so I don’t have to ? now to the underfloor heating Doh ???? my fault dam it, I tried to clean out the flow adjusters last week and I screwed them all the way down so nothing can flow past. reset the flows and inlet manifold is now hot ? so no asbo for the wife, just waiting for the floor to heat up and I’ll put the panel back to hide all the pipe work. wouldn’t have touched it if it weren’t for a boiler breakdown and new bathroom fitted, I know a lot more about the workings of the mixer valve now as well. it’s an age thing now I’m old I keep telling myself, thanks for all the replies. Link to comment Share on other sites More sharing options...
