My thermally broken windows are going to sit with 15mm overlap on exterior block wall but the cavity closer extends 25mm past the window exterior. Has anybody had experience of rendering on to Cavity closer upvc?
You can’t render onto cavity closers
You will have to dab a board over onto the exposed block and fix a 25 x12 mil SS trim to the frame to catch the other edge of the reveal board
Looking at outside not inside
Then close the cavity with block and damp ours
Cavity closers should be on the inside of the building
