I am having my sand and cement screed done in two weeks so just now finishing off getting everything ready.
I read a lot on here about fitting expansion joints in doorways but i can't seem to find the product everyone is using, could someone please point me in the right direction on what i need to buy so I can get it ticked off my list !
Not an expansion joint, doorways are crack points.
the screed will shrink and crack, while wet cut a slit at least half the depth of the screed across the door threshold. This causes the crack to form where you want it.
This Has been asked before I normally buy a 10 mil 2400x1200 sheet of fluted plastic
Same as the 5 mil stuff used for floor protection
Rip it into 100 mill strips Put on in each doorway or opening Cut it off with a Stanley knife the following day
Would this just be pushed down to sit on top of the heating pipes or would i better to slot it to sit over them ?
Screed through the doorway Then cut it back with a trowel Push the strip against
Only takes a minute per strip
We normally put our tile expansion over it
