Tetrarch Posted August 17, 2021 Posted August 17, 2021 House is a 1914-built detached that is (PP pending) going to be extended and refurbed, including a complete external re-rendering and intternal re-plastering. The plan is to have UFH downstairs and rads upstairs fed mainly from an ASHP. Also, considering an MVHR to provide superior ventilation in a more sealed house The insulation is going to be substantially upgraded. From here https://www.thegreenage.co.uk/thickness-solid-wall-insulation-u-values-can-achieve/ it states a requirement to add 67mm of PIR to a solid wall to achieve a u-value of 0.3 My current thoughts are to add 25mm internal insulation using insulated plasterboard and 50mm outside on the old solid walls under a new render.This will avoid creating too much depth on the reveals but will improve the u-values to the right levels Any reason why this solution won't work? Regards Tet
the_r_sole Posted August 17, 2021 Posted August 17, 2021 get dew point analysis done, it's generally not a good idea to insulate both sides of anything as you'll trap moisture into the structure
Ferdinand Posted August 17, 2021 Posted August 17, 2021 TBH those are minimal amounts of insulation, even if it was just on one side. And since it is scraping through building standards I assume it is PIR. I would suggest something more like 120mm or 150mm of PIR on the outside if you want to use that, and a target U vale of more like 0.13 or 0,15. The extra is far more cost-effective, as you still only have to do one set of structure, fitting and labour. Or go for a thicker layer of EPS, which is less expensive. Do not let anyone tell you to be unambitious.
