luz624 Posted August 10, 2021 Posted August 10, 2021 Hello, I am not particularly clued up on the technical world of ventilation, so please bear with me... I have been feeling quite stressed trying to figure out an optimal ventilation system. I am completely renovating my 70m2 2-bedroom ground floor period conversion flat. As part of this, I will be adding decent insulation, using breather membranes, etc. While energy saving is important, for me it is definitely secondary to the health goals. I would primarily like to achieve - (1) optimal levels of humidity (to reduce chance of mould, as we have had this previously), and then (2) clean, filtered air (no VOCs, pollen, spores etc filtered out). I believe a MVHR system is the gold standard, and I am trying to see if that's possible to fit, however I am extremely limited on space. I am trying to see if I could fit in under the bathroom vanity and build a cupboard around it.. however I know that's going to be extremely tight. I think I could maybe get the main unit in, but I'm unsure about distribution boxes. Alternatively, I have briefly looked at dMEV in each of the wet areas - which could help (1) humidity levels. I would then have to ensure there's adequate ventilation through trickle vents etc in the rest of the property, and use a standalone air filter. I don't know much about PIV, and if this is an option? Though it looks like space would be an issue with that too. Any thoughts on best approach?
Roundtuit Posted August 10, 2021 Posted August 10, 2021 A 'standard' mvhr system takes up a lot of space when you factor in the unit, manifolds, silencers and the fact that you need ducting between all the components. Maybe have a look at something like this: https://fresh-r.eu/en/ No idea if it works or what the cost is, but on paper might be a solution! 1
Nickfromwales Posted August 10, 2021 Posted August 10, 2021 Hi. Why not go for individual MVHR units per room? link 1
Faz Posted August 10, 2021 Posted August 10, 2021 MVHR is a game changer in a flat - I have built 92 of then some with and some without. Never had a condensation whinge where we have installed it. Solarcrest have done our stuff (and are doing my house although a 3,000 sq. ft. house doesn't really call for it tbh). Solarcrest supply, install and commission the lot with a 7 year warranty. Others seem to supply and point to a installer - there have been issues for some who have gone down this route. 1
Nickfromwales Posted August 10, 2021 Posted August 10, 2021 Good to remember that there are rectangular ducts available and reduced size ( 75mm and 50mm ) round ducts too. CVC Direct supplied me with 225mm x 25mm for a project where we managed to hide the equivalent of 92mm round duct in the 35mm service void of an MBC TF build. Not a single bit of boxing in anywhere. They do supply only + design, or supply and fit and, I use them in both capacities with exceptionally good results. Great team and a fantastic pre / after sales support service too. @luz624 Just read that it's for a flat here, so without plans to show rooms vs outside walls etc it's a little tricky to offer much more advice. Do you have plans you can upload? 1
luz624 Posted August 11, 2021 Author Posted August 11, 2021 Thank you all for the replies. I'll take a look at some of the links shared and see if they could be suitable. @Nickfromwales Do you mind if I DM you with the plans? Would appreciate if you have any thoughts!
luz624 Posted August 11, 2021 Author Posted August 11, 2021 The external walls are essentially at the front of the property (Victorian terrace), the W.C./shower area, and the extension where the kitchen area is. The rest of the walls are party walls with neighbours. My husband thinks a slimline MVHR unit could be wall mounted where I've marked in green (and then the planned kitchen units pushed in a little). And the unit either boxed into a kitchen cupboard, or a false wall type thing added with a concealed door for maintenance. The roof here will be a pitched roof, but I'm unsure how the ducting would fit into this (apologies again - all so new to me!) Could the ducting run through the rafters/insulation.... or would we need a separate service void...? Sorry if that's a stupid question
