nickw Posted August 9, 2021 Share Posted August 9, 2021 As per title , any good or bad ones out there to watch for , will need approx 12m run. Link to comment Share on other sites More sharing options...
jack Posted August 10, 2021 Share Posted August 10, 2021 Main things to consider are: - diameter (we went for 28mm pushfit plastic) - insulation (90% of our ~9m runs are through the middle of the insulation under our slab. Alternatively, you can insulate with nitrile rubber, or buy special pre-insulated ASHP pipes, although the latter is expensive) - oxygen tightness (copper is fine, as is plastic pipework with an oxygen barrier) Link to comment Share on other sites More sharing options...
Nickfromwales Posted August 10, 2021 Share Posted August 10, 2021 Primo Duo is the norm for me if installing where the pipe is subterranean. Link to comment Share on other sites More sharing options...
nickw Posted August 11, 2021 Author Share Posted August 11, 2021 thx guys Link to comment Share on other sites More sharing options...
