epsilonGreedy Posted August 5, 2021 Posted August 5, 2021 I ask because I have a 4x8 sheet left over and it is just enough to run under the wooden boxed eaves of my single storey utility extension. The rafters are on 600mm centres.
ToughButterCup Posted August 5, 2021 Posted August 5, 2021 My first thought was .... water. OSB3 therefore, or similar. Soffit board is commonly much thinner than 18mm, I understand
epsilonGreedy Posted August 5, 2021 Author Posted August 5, 2021 15 minutes ago, ToughButterCup said: My first thought was .... water. OSB3 therefore, or similar. Soffit board is commonly much thinner than 18mm, I understand Hnmm even when painted OSB would look a bit rough. I hope the underside of the eaves will not get wet too often. If done correctly I will have plastic eave trays over the top of the fascia with an angled flap directing run off water direct into the centre of the gutter. There will also be a 5 to 10mm recess along the bottom of the fascia up to the base of the soffit. I am hoping that a thick soffit will allow for fewer screws to keep it tucked up and in place. I really don't want to look up in 5 years time and detect sag between the 600mm centres.
tonyshouse Posted August 5, 2021 Posted August 5, 2021 Soffit boards should not get wet, 6mm ply would do so 18 will work,
