Brenty1892 Posted August 4, 2021 Posted August 4, 2021 Hi All, I'm having to pour about 10-12 bags of self levelling compound single handed and i'm looking for some advice on two potential methods i'm thinking of. Firstly, good old fashioned mix a bucket and pour but i'm worried about timings. Secondly, mix all of the bags in an empty drum i have and then drill a 1" hole in the bottom and let it flow. Not sure if this a crazy or if it would work Its Mapei 3240 if that makes any difference and floor area is about 30 sq metres Thanks for any help
markc Posted August 4, 2021 Posted August 4, 2021 10-12 bags isn’t a lot. the time you spent mixing in a large drum would probably be more than batching. get yourself set up, materials close to where you are working, good mixer, pre measured water level in container etc. have a break, cup of tea and then go for it. mixabag and tip it out, straight onto next bag.
PeterW Posted August 4, 2021 Posted August 4, 2021 Add an extra 1/2 litre per bag, get the floor sopping wet with a mop and bucket and clean water first and then mix / pour etc using a Plasterer’s bucket and a power blender. Have 3 or 4 marked up water buckets filled to a line and then just keep filling …
