Kripa Posted July 27, 2021 Posted July 27, 2021 (edited) Hi all, I'm new to this forum and would just like to introduce myself. I'm a new mum currently on maternity leave. We decided to start our orangery and garden and are 2 months into the project via builders. Unfortunately we have had to take the project on ourselves as the lead builder is unwell and will no longer be coming. I think it's quite exciting to learn something new and be hands on in finishing this job. The main structure of the orangery has been built and the next step is to level the surface with self levelling compound prior to fitting the insulation (40mm depth we need to level). I would appreciate if anyone could provide the method on how to do this properly. Thanks in advance Kripa Edited July 27, 2021 by Kripa
MikeSharp01 Posted July 27, 2021 Posted July 27, 2021 Welcome to THE forum for people like us! Take a look at this video - long but with more than enough detail to allow you to tackle it.
PeterW Posted July 27, 2021 Posted July 27, 2021 37 minutes ago, Kripa said: The main structure of the orangery has been built and the next step is to level the surface with self levelling compound prior to fitting the insulation (40mm depth we need to level). Welcome. Your statement makes no sense - what’s the floor build up from ground upward ..?? Self Levelling is only used normally to make up the top surface prior to final finish such as tiles or other flooring, 40mm below insulation is calling out for 40mm more insulation ..!!
Kripa Posted July 28, 2021 Author Posted July 28, 2021 Thanks a lot Mike this is an extremely informative video and I think I am now comfortable that I know exactly what to do to complete this next step of our building job. Peter - I am fully aware that self levelling compound is used to make up the top surface prior to underfloor heating and tiling. My question was around what is the best method/process for applying self levelling compound. Mike's video has answered my question
