WWilts Posted July 21, 2021 Posted July 21, 2021 (edited) Self build What is the correct rate of VAT for site clearance services? for services installation (trenches and commissioning)? for drainage installation? (supply and fit) Main contractor being used. Agreed zero VAT at start. Some works not included in that contract (above), but a quote from the same main contractor stated "plus VAT". So correct VAT rate is important Edited July 21, 2021 by WWilts
nod Posted July 21, 2021 Posted July 21, 2021 Drainage etc should be zero rated If I remember right we paid vat on the muck away As I’ve stated previously some trades either can’t or won’t zero rate materials So it may be worth buying the drainage material or asking your contractor to In any case most contractors will add at least 20% on for supplying materials It may be worth getting another quote 1
Bitpipe Posted July 21, 2021 Posted July 21, 2021 All works 'closely associated' with the build (assuming PP granted and going back down to ground level) are zero rated. Plant hire to you and professional services are standard rated. New utility connections are zero, utility moves (like a meter) are standard. 1
WWilts Posted September 27, 2022 Author Posted September 27, 2022 New build in progress Kitchen worktop supply and fit (kitchen supplier subcontracts a specialist supplier and fitter). What is the correct VAT rate for supply and fit of the worktop? Zero? If so, what chapter and verse can be quoted to the kitchen supplier so that they don't do their usual practice of charging 20% VAT for the supply and fit?
