Anyone recommend a classy wall hung WC that is less than 450mm?
I only have 500mm to the door opening potentially hitting the WC which is why it needs to be a short projection.
It’s seeming harder to find than I thought.
shortest I’ve found so far is 460mm for a wall hung rimless that will fit onto the new Grohe framed concealed cistern Rapid SLX(which I’ve gone for because it’s the quietest on the market apparently).
I think most seats are 450-460 from hinge to front edge.
How about... Keep the frame but ditch the cistern so the frame can be moved back (waste pipe allowing?). Then fit the cistern high up in cabinetry. Effectively recessing the frame and WC into the "wall".
Edited by Temp
