ashthekid Posted July 6, 2021 Posted July 6, 2021 Anyone recommend a classy wall hung WC that is less than 450mm? I only have 500mm to the door opening potentially hitting the WC which is why it needs to be a short projection. It’s seeming harder to find than I thought. shortest I’ve found so far is 460mm for a wall hung rimless that will fit onto the new Grohe framed concealed cistern Rapid SLX(which I’ve gone for because it’s the quietest on the market apparently).
PeterW Posted July 7, 2021 Posted July 7, 2021 Can you move the WC or change the door to a pocket door ..??
ashthekid Posted July 7, 2021 Author Posted July 7, 2021 Sadly not. Have already considered those options.
Temp Posted July 7, 2021 Posted July 7, 2021 (edited) I think most seats are 450-460 from hinge to front edge. How about... Keep the frame but ditch the cistern so the frame can be moved back (waste pipe allowing?). Then fit the cistern high up in cabinetry. Effectively recessing the frame and WC into the "wall". Edited July 7, 2021 by Temp
ashthekid Posted July 7, 2021 Author Posted July 7, 2021 Don’t think that would work. I just need to find a short cistern. Does it exist?
Onoff Posted July 7, 2021 Posted July 7, 2021 (edited) 34 minutes ago, ashthekid said: Don’t think that would work. I just need to find a short cistern. Does it exist? Struggling! 450mm: https://bathroomsatsource.com/product/gsi-norm-45-wall-hung-wc-pan-and-soft-close-seat-gs8610/ https://bathroomvillage.com/products/gsi-norm-45-wall-hung-wc-pan-450-x-350mm?variant=14053341823028&gclid=CjwKCAjwoZWHBhBgEiwAiMN66XpyVUNMGky3MVgDlJIqaMLjRiJCSdQ-8WdY9ZNVM4_dsrEKqnaiRhoCv24QAvD_BwE Edited July 7, 2021 by Onoff
Temp Posted July 8, 2021 Posted July 8, 2021 (edited) 430mm.. https://www.ukbathrooms.com/products/crosswater-pier-wall-hung-compact-rimless-wc.html Think also sold under the name "Bauhaus Pier". Edited July 8, 2021 by Temp
