MikeSharp01 Posted June 9, 2021 Posted June 9, 2021 I am about to embark on the vertical tile hanging for our build and I am looking for recommendations for a good fibre cement cutter / Guillotine, preferably with a hole punch. The little hand held Plier type don't look they will work - but they might be more capable than I think, the slates are 300mm wide. Any body got any good ideas?
Hobbiniho Posted June 9, 2021 Posted June 9, 2021 what type of fibre cement tiles are you using? and how thick are they? iv fitted many roofs with Eternit Thrutone Slate and just used a heavy duty metal scribe to scribe them and then snapped them. then used a bosch multi construction bit to drill holes.
markc Posted June 9, 2021 Posted June 9, 2021 Scribe and fold (similar to plaster board) for cutting, slaters knife/hatchet for trimming and shaping. Or you could use a grinder and diamond disc but the dust is annoying
MikeSharp01 Posted June 9, 2021 Author Posted June 9, 2021 44 minutes ago, Hobbiniho said: what type of fibre cement tiles are you using? SVK 5mm Ardonit fibre cement, want a crisp edge if I can get one,
