Garage demolition, side porch to replace it. Small, Building Regs exempt. Design fixed by planner. Existing external walls of main dwelling will form 2 (internal) sides of the porch. Currently garage has a double skin wall (outer stone, inner brick). Concrete floor. About 550mm below main dwelling floor level.
Can the existing foundations for the front elevation be retained and used? What would determine whether or not?
Any particular approach recommended to join the side wall securely to the existing external side wall?
If retaining the existing concrete slab, what layers would you use to build it up by about 275mm? Then it will be level with an existing step that leads from main dwelling down to existing garage floor.
Normally you would get a Structural Engineer to determine the method of joining the two and foundations also
Followed up with a drawing
Who has told you you don’t need building regs
Structural alterations normally require BC
LA building control. Exempt, and they will not issue completion certificate
I think porches are exempt but only if you retain the external grade door between house and porch. If you are replacing the door with an internal style door  and heating the "porch" then I think you do need building control.
If you want to build in brick I think you need to dig a hole next to the slab to see if its got proper foundations. If not then perhaps look at a timber frame?
I'm thinking you need a few courses of bricks then a DPC and DPM on sand blind. Then insulation and screed. 200mm PIR and 75mm screedwould be good.
