Porthole Posted May 28, 2021 Posted May 28, 2021 Hi Just wondered if anyone can help. Am looking at getting 2 large rooflights 3m by 1m for our flat roof extension. The prices for supply and installation vary quite a bit from £7.6k to £3.9k. Just wondered if anyone can enlighten me as to why there is such a range of pricing. Would a cheaper option be a false economy? I'm not really sure what to look out for. Also, any recommendations for glazing companies in Surrey? Many thanks !!!
SteamyTea Posted May 28, 2021 Posted May 28, 2021 (edited) 1 hour ago, Porthole said: I'm not really sure what to look out for Building overheating. 6m2 could easily let in the same power as 2 3kW fan heaters. I am sure @pocster has the ideal sized roof light for you, especially if you have not cut the hole yet. Edited May 28, 2021 by SteamyTea
Pocster Posted May 28, 2021 Posted May 28, 2021 1 hour ago, SteamyTea said: Building overheating. 6m2 could easily let in the same power as 2 3kW fan heaters. I am sure @pocster has the ideal sized roof light for you, especially if you have not cut the hole yet. Yes indeed . My shop is always open
PeterW Posted May 28, 2021 Posted May 28, 2021 24 minutes ago, pocster said: Yes indeed . My shop is always open He always lets customers in.... like his walk on glazing that lets water in.... 3 hours ago, Porthole said: Am looking at getting 2 large rooflights 3m by 1m for our flat roof extension They are huge - and expensive as you’ve found out. I would I consider 4 at 1x1 which is pretty much a standard size and much easier to handle.
Pocster Posted May 28, 2021 Posted May 28, 2021 21 minutes ago, PeterW said: He always lets customers in.... like his walk on glazing that lets water in.... They are huge - and expensive as you’ve found out. I would I consider 4 at 1x1 which is pretty much a standard size and much easier to handle. Excuse me . You don’t recommend anything . @Porthole I can save you a small fortune !!
