Crofter Posted May 16, 2021 Posted May 16, 2021 I'm needing a laminate threshold strip 1200mm long, ideally in a light grey wood effect but something neutral like a chrome finish would work too. Surprised not to be able to find anything after trawling through half the internet. Is it normal practice to just join two short strips instead? Thanks
PeterW Posted May 16, 2021 Posted May 16, 2021 Is this between two level laminate floors for expansion through a doorway ..?? You can get standard ones in 2.5m - think even B&Q have them.
Crofter Posted May 16, 2021 Author Posted May 16, 2021 It's where the laminate meets an external French door. There's a slight change in level, with a step up of about 5mm.
Temp Posted May 16, 2021 Posted May 16, 2021 (edited) Something like this? Various colours 1.8m long.. https://www.ebay.co.uk/itm/Aluminium-Door-Bars-Threshold-Strip-Transition-Trim-Laminate-Tiles-47-MM-X180-CM/254764646839 Narrower.. https://www.ebay.co.uk/itm/200-CM-Door-Bars-Threshold-Strip-Transition-Trim-Laminate-Tiles-VARIOUS-SIZES/272129082558?item=272129082558&ssPageName=STRK:MESE:IT&pageci=5aa2cf47-bfcc-46db-9925-e16551a2cd7f&redirect=mobile Search for Aluminium Threshold Strip Transition Edited May 16, 2021 by Temp 1
Crofter Posted May 17, 2021 Author Posted May 17, 2021 9 hours ago, Temp said: Something like this? Various colours 1.8m long.. https://www.ebay.co.uk/itm/Aluminium-Door-Bars-Threshold-Strip-Transition-Trim-Laminate-Tiles-47-MM-X180-CM/254764646839 Narrower.. https://www.ebay.co.uk/itm/200-CM-Door-Bars-Threshold-Strip-Transition-Trim-Laminate-Tiles-VARIOUS-SIZES/272129082558?item=272129082558&ssPageName=STRK:MESE:IT&pageci=5aa2cf47-bfcc-46db-9925-e16551a2cd7f&redirect=mobile Search for Aluminium Threshold Strip Transition So nearly perfect... good find... foiled by the good old "doesn't post to Scottish islands". But at least I know they do exist now so I'm not wasting my time searching. Thanks!
PeterW Posted May 17, 2021 Posted May 17, 2021 12 minutes ago, Crofter said: So nearly perfect... good find... foiled by the good old "doesn't post to Scottish islands". But at least I know they do exist now so I'm not wasting my time searching. Thanks! so if it would work I’m happy to get it posted to me and cut it down to say 50mm over size and post on ..?? 1
Crofter Posted May 17, 2021 Author Posted May 17, 2021 12 hours ago, PeterW said: so if it would work I’m happy to get it posted to me and cut it down to say 50mm over size and post on ..?? That is a very generous offer, thank you! I will take a spin round my local options and see if I have any luck there, but I may have to to take you up on that.
Crofter Posted May 18, 2021 Author Posted May 18, 2021 Update- I was able to get a 2.4m length of brushed aluminium threshold locally. Not exactly what I wanted but I will make it fit. And the offcuts won't go to waste.
