Integral garage wall insulation
PI build
Our renovation has a 50mm cavity wall between the house and garage. We would like to fit insulation on the garage side of the wall. Our plans have plasterboard coated PIR for this. I do not like the idea of plasterboard on the garage walls as this is an unheated space and would prefer something less hygroscopic. Some external wall insulation systems look over the top  - What would be the simplest way of achieving this?
You can dot and fab the insulated plasterboard directly to the masonry
But you will need to mechanically fix it also Usually a simply knock in 16 per board
I use a lot of glass rock muti board for fireproofing beans While it’s great for FP It will offer little for insulation
Insulated pb is prone to damp issues like PB
