Looking to source service battens for the build (i.e. between internal PIR insulation and plasterboard). Is there any reason why treated timber cannot be used internally - e.g. 25mm x 50mm roofing battens? From a quick Google it appears should not be an issue if the wood is not used for worktops etc.
2 minutes ago, ProDave said:
Treated is fine.  Sometimes it is hard to find untreated battens in a builders merchant.
Thanks @ProDave.
