wozza Posted April 18, 2021 Posted April 18, 2021 Hi All, When flushing my toilet the water level in the shower drops by about 5mm - it then rises back up and fluctuates up and a down a bit, there does not appear to be any water lost. The end of the soil pipe is sealed. If I remove the seal and fit either a 110mm or 40mm AAV then there is no change - the water still drops about 5 mm then fluctuates up and down for a few seconds - there does not appear to be any water lost. The sink has a Mcalpine anti syphon trap, I have tried with this blanked off as well to see if it makes a difference and it doesnt. I have even tried flushing the loo and pouring a bucket of water into it at the same time, but again the result was the same. If vent the soil pipe into the room then I do not get any movement in the water levels. So it appears that I do have a very small amount pressure in the pipes when flushing the loo but not enough to activate the AAVs or the anti syphon trap. Do I need to be worried about such a small movement of the water level? Should I vent the pipe to atmosphere or fit an AAV as a precaution (venting to ATM will be a ball ache but do able) Thanks, Wozza.
